For a workflow or business process to interact with a Laserfiche repository, certain connection information must be known: the Laserfiche Server, the repository, and the user that you want Workflow to interact with the repository as. This information is stored as the workflow or business process's connection profile.
A connection profile can be unique to a workflow or business process. When creating a unique profile, you can use information saved as a common or user profile as a master profile and modify it according to your needs. Any changes to the copied information will only affect the profile you are creating and will not change the master. These newly created profiles are only available to the workflow or business process definition in which they are created.
If a workflow is using the default connection profile, its unique connection profile is automatically created using the information in the default profile as the master.
Note: Workflow and business process definitions are created in the same way.
To create a connection profile
 at the top of the Properties Pane.) From the Referenced Objects property box, select Connection Profiles from the drop-down menu and click Manage referenced properties. In the Referenced Object Manager, click Manage.
Note: You are only copying the information from the common or user connection profile, any changes to the information in this dialog box will only apply to the specific profile you are creating and will not affect the common or user profile.
Example: If you add the Assign Field Values activity to your workflow definition, the user you define must have sufficient rights to assign templates to all entries that the workflow will be performed on.
To modify a custom profile
To delete a custom profile
Note: Deleting a connection profile does not affect any common or user profiles.
                     This documentation is specific to version 9.0. You can find the most up-to-date help files for the latest version at Current Online Laserfiche Product Help Files. For further help or feedback, please see the Laserfiche Support Site. |
                     © 2013 Laserfiche  |
